When I copy a bullet, it copies the note along with it too, which is not what I want. Is there a way to just copy the bullet wihtout copying the associated note?
With Ctrl+A you can only copy the node text. But it does not work with multiple nodes if that is what you want.
@Philipp is right – if you select the entire bullet, everything is copied. For text copy only select the bullet text.
You could use the export option, but there’s bug blocking it right now: Notes do not get hidden by "Export visible items only" export option It should be possible after we fix this bug! ![]()
