I know there’s back and forth commands for jumping between documents, but some individual documents (like mine) are heavily nested—so going back and forth between bullets/breadcrumbs and documents would be super helpful
On Mac please try Cmd+Left/Right. macOS system uses Alt+Left/Right for something important (switching spaces maybe? I don’t remember exactly what), and we couldn’t override that.
It will go back one step in history. If you zoomed in, it will zoom back. Just like a browser. Not sure if that’s what you wanted?
I just tried it on Windows 10 and it works exactly like a browser back/forward. Only possibilities I can think of in your case is if you override the zoom in/out shortcuts with those instead of the default ones.
Yeah I believe there’s currently no way to set those shortcuts because they are controlled by the Electron app portion, and it’s a bit more difficult to change because they reside in the menubar (press alt once to show menubar).
