Which browser are you using?
I use Dynalist on my iPhone 12 Pro daily. With chrome. About a week about it stopped working. I cannot clink into or edit lists. I tried quitting out and restarting. I tried logging out and in. The problem persists. Making the app unusable.
I donāt know what version of Dynalist Iām on but my apps auto update.
