Ipad sync error with Bookmarks
Very happy with Dynalist - restarted the use a few weeks ago. Have good experience with website, IPhone app but see a bug in the Ipad version.
Expect that bookmarks sync from the website and app. This works at the iPhone but the Ipad version looks not to sync correct.
The result is that the bookmarks don’t sync. It looks if they still from a few weeks ago. Did a reinstall of the app and new login but that did not help.
Ipad Mini 11.1
App version 1.1.16
A reinstall normally solves this kind of issue, but apparently it didn’t work for your iPad.
Could you give us some more information on what happened? For example, did you add new bookmarks or edit name of existing bookmarks? And where did you do that, iPhone app or the web app?
The iPhone app and iPad app is the same app, so I doubt they would behaves differently. Are they on the same iOS version?
Sorry for so many questions! It’s a weird bug indeed.
Hi @Christiaan, we’re cleaning up the bugs and would like to know if the bug is still happening to you? If not we’ll close this bug.
Yes this can be closed
