iOS hardware keyboard word selection not visible
  • type with a CJK e,g, Chinese pinyin or other iOS stock input method keyboard that requires candidate word selection
  • with a hardware keyboard
  • system and Dynalist app should be set to dark theme
  • web selection show as normal
  • the first word selection candidate is not visible as the font itself is in black, and the background colour is in back
  • sometimes when the hardware keyboard is activated, the screen still show a blank on-screen keyboard
    (Both issues indicated in the image below)
  • This should be an issue of the app colour scheme, since the same issue does not happen to other apps e.g. Safari (I am a new user so I could not upload more than one image to demonstrate the normal behaviour, maybe I will add in the comments if you need it)
iOS 26.4
App version 1.4.16
The normal behaviour (as in Safari):
Additional info: the blank on-screen keyboard can be reproduced when you are typing with hardware keyboard and press enter to create a new bullet - the blank on screen keyboard will pop up
