In the past I could easily move items up and down using ctrl+arros up/down but now it seems I can’t. I’m not sure if some update changed it or if it’s a bug.
There’s been no update.
Try opening your browser into incognito mode and test on this page https://dynalist.io/demo/4kpmt51ULD2RgJlcb8IZLZai
Works for me
It seems it doesn’t work either. I don’t know why this happens tbh.
PROBLEM SOLVED: I was using a chrome extension that used ctrl+up/down as a shortcut and that made dynalist unable to work properly. My bad.
