Dear Dynalisters,
We know you have an exciting feature request that will make Dynalist better, and weāre excited to hear it!
To make sure your feature request has maximized impact and the highest chance of getting noticed and implemented, we strongly recommend taking a few minutes to read this article: https://github.com/rstudio/rstudio/wiki/Writing-Good-Feature-Requests.
It covers a few common mistakes people make and saves lots of back-and-forths if everyone follows them. Iāll paraphrase the post below specifically for Dynalist:
Make sure itās unique
Your first job when filing a feature request is to make sure that it isnāt already filed. We get feature requests every day, so thereās a reasonable chance that someone else has had the same idea; just search in our forum. If you donāt find it, try to think of other keywords other people might use.
If you find that someone else has already filed the feature request, donāt just move on! Instead, help us know that youāre interested, too:
- Add a Like to the feature request to vote for it. This helps the request become more visible to the team.
- Optionally add a comment with any insight and background you have that isnāt already part of the conversation.
Describe your use case
A good feature request describes the context in which the feature will be used. Itās easy to forget to write about context because you already know it so well that it seems obvious! Just like any tool, though, the best improvements are made with a deep understanding of how itās used.
Vague
Add a button to bulk convert all uploaded files from private to public
Improved
I uploaded lots of files when first starting to use Dynalist. However, without knowing the privacy settings, I uploaded them with the default private permission and they canāt be viewed by my collaborators. I can upload them again, but itās time-consuming, and Iāve almost run out of my monthly file upload quota.
Describe the problem and propose a solution
Most feature requests only describe solutions ā that is, a specific product improvement.
Make your feature request better by describing the problem you are facing, and only then proposing the feature request as one solution to that problem. You might find that the product team (or another Dynalist user) proposes a different solution you hadnāt thought of.
Solution Only
Make it so scrolling with the mouse wheel is twice as fast when I hold down Ctrl.
Problem and Solution
When I open a document, I start at the top. I often want to scroll to the very bottom to add an item. That takes a long time because my documents are sometimes thousands of lines long. Iād like to be able to scroll faster, and in my second favorite program, I can do that by holding down Ctrl while I scroll.
Link to examples and research
Is there already software that has the behavior youāre interested in? What is it, and how does it work?
Can you give a concrete example of how youād use the feature? A relevant code sample?
What other ways did you try to solve your problem?
Are there any relevant existing standards or conventions?
Can you draw a picture of what youāre imagining?
You get the idea!
State the title simply and succinctly
Thereās no need to decorate the title of your issue with words like Enhancement or Request . Use your feature requestās title to state it as simply and clearly as possible, with ordinary casing. This will help other people find it when theyāre looking to contribute.
Bad Title
[REQUEST] Scrolling is TERRIBLE on WINDOWS APP, make it 2x faster
Good title
Increase scroll speed on Windows
Donāt disguise as a bug, and be polite
It should go without saying, but unfortunately it doesnāt: donāt file a feature request as if it were a bug. It might feel like a missing feature ābreaksā the product for your use case, but that doesnāt make it a bug!
Itās also not helpful to add comments such as āitās shameful that this request has been ignoredā or āitās been years, why hasnāt this been implemented yet?ā. Many people who are reading this use Dynalist for free, and Dynalist has a small team (the 2 of us do everything from development to answering support to buying office chairs). We care very much about our community and we probably love your idea, but we can only do so many features in each month while keeping quality and stability high. Help us focus on the very best ones by writing great requests!
Thank you!
Many of the best parts of Dynalist started out as ideas from the user community, and weāre very grateful for each one. Thanks so much for taking the time to write up a thoughtful feature request.
- the Dynalist Team
