I can’t discern what the third key invoked is to clear a color label; command-shift-[]? If it’s the lower symbol on the tilde key [~], it’s not working on my Mac. Thanks!
Edit- I just discovered that this key combination works in Safari, but not in Chrome.
Erica
January 23, 2017, 8:36am
3
Neill_Cohen:
I can’t discern what the third key invoked is to clear a color label; command-shift- ? If it’s the lower symbol on the tilde key [~], it’s not working on my Mac. Thanks!
The default key is Cmd+Shift+Backtick (backtick is the key on the left of the 1). You can customize it though!
can I remove multiple color labels at once?
Old post, but this perhaps belongs here…
私も一貫した色のシステムを持っているので、色のカスタマイズ機能を切に望んでいます。特に、ピンク色は私にとって重要な色です。もしプロ版にその機能があれば、私は喜んでそれにお金を払うでしょう。
I also have a consistent color system, so I really want the color customization feature. In particular, pink is an important color for me. If the pro version has that feature, I will gladly pay for it.
