In the Dynalist settings, there is an option to Highlight Current Item, which changes the background of the item/node you are currently editing so you don’t get lost. The problem is that I use dark mode, and it’s actually pretty hard to see the altered background color of the item I’m currently editing even with that option enabled. Is there a way with CSS to change this background color of the current item into a bit lighter gray?
Thanks for your reply. However, it didn’t seem to do the trick. To be clear, I’m not talking about anything to do with the background color of nodes that are overdue. I’m referring to the bar in the left margin of the currently selected node (i.e., the node where the cursor is blinking). In the image below, you can faintly see the grayish bar next to the line that begins with “Search for an answer…”
I want to change the color of that bar so that I can more quickly identify where the cursor is on the screen.
