Highlight multiple lines of text, particularly filled with a lot of code.
It should stay highlighted.
It deselects the text, or cancels the highlight. It never sticks.
Windows 10, both the app and website.
Iām highlighting the text from the very bottom and last character to the top. And hovering over the bullet point doesnāt seem to lock-in the highlight.
Iāve noticed in some other other text, that sometimes if I do not highlight at the very end*, then it will also fail to highlight.
