select text you want to format as code
try to format as code with shortcut âFormat as codeâ: command + `
to format text selected as code
It doesnât format. It only works when you change the shortcut to something including the âoptionâ key (e.g. option + c). But I donât like shortcuts including the âoptionâ key.
I have already tried the following custom shortcuts without success to format text as code.
cmd g
cmd shift g
cmd j
cmd shift j
cmd \
cmd toggle ( cmd + ' )
Which operating system are you using? MacBook Pro (15-inch, 2017) version 10.14.6 Mojave
Which browser are you using? Google chrome (having the same issues here)
If youâre using a desktop or mobile app, whatâs the version number of Dynalist? 1.2.3
Are you using any third-party scripts for Dynalist, e.g. PowerPack? Nope
Is not that my âcmdâ key is broken or something, I also used the same custom shortcuts mentioned above to change the âMake boldâ shortcut feature and they worked. I think something is broken for the format as code feature. The custom shortcuts feature work. Just that something doesnât work with the âFormat as codeâ shortcut.
Ah I see. Unfortunately that might still be due to the âCycle through windowsâ shortcut on MacOS. I believe you should be able to change it according to
That is such a common and fundamental shortcut on macOS - I wish Dynalist would change the shortcut instead of expecting people do disable the Mac global shortcut
I understand what you mean. Unfortunately at this point I donât think we can change these shortcuts just because people may already be relying on it.
It doesnât seem like the case for you, but if you had Dynalist Pro, you would be able to customize the shortcut to another key combo.
