custom keymapping
most DAWs and video editors has this
with custom keymapping it takes zero time to adapt to the new environment, so the differences in the UI will be only feature-related, but thatâs what for we switched in the first place, didnât we?
If itâs broken, please post a bug report with detailed steps would help us fix it. And also many people are using it without any issues, myself included, so it could be something wrong on your end (how you set it up).
And no offense, posting a feature request for an existing feature without mentioning youâve tried it is not exactly helpful.
WorkFlowy features do not match to Dynalist one-to-one, and Iâm not even sure what do you mean by âpresetâ. Do you mean a text file that stores your configurations? Or just âmagicallyâ import all your settings from WorkFlowy? Iâm sorry but they have to expose it somehow for us to access it.
I donât know how many shortcuts youâd like to set up, but with the amount of frequently used shortcuts WorkFlowy has, it wonât take more than a few minutes. That doesnât warrant spending our development time on it, in my opinion.
The problem is that we have to check everyday if WorkFlowyâs shortcuts have changed, and if we provide the preset of WorkFlowy, we may be asked to provide presets for Checkvist, Moo.do, etc. as wellâŚ
If these other applications provide a way to programmatically pull the shortcuts, we can consider it. Right now it sounds like it adds too much maintenance work for us without adding too much benefit. Out of the 15 shortcuts you posted, there are only 5 conflicts, the starred page ones are not applicable. It would take a few minutes max to scan the list and make your adjustments.
Weâre just a team of 2 doing everything from support to server infrastructure, so sorry I donât think weâre spending time on this. Thanks for the suggestion, appreciate it.
there might be community-edited section with other shortcuts though. Preset + date when this preset was updated last time. For those who may concern. It might be about 100% users who are switching from other apps, because kids usually start with the default ones.
