Hello! Your app is great and very useful!
I have only one problem with your app it’s about shortcut for expand / collapse items. There is shortcut for “ctrl+.” but it doesn’t work properly by some reason. When I’m using trial pro version I turned off shortcut for help “ctrl+/” and this combination works well for expand / collapse. But now pro trial is over and custom shortcut was disabled. Can you advice what’s the problem with this shortcuts and how to solve it? It’s strange also because combination “ctrl+shift+.” works well for expand all / collapse all.
Thank you in advance!
Browser: Chrome
OS: Ubuntu
Keyboard with standart QWERTY layout
Yeah, this has nothing to do with language or keyboard. I have set to English/US and there is no functioning keyboard shortcut to expand one level only. If there is something in Chrome that makes Ctrl Period problematic, can this be switched to or duplicated in some other key combo?
I found it: AdBlock uses Ctrl-Period as a shortcut, and it’s interfering. The resolution is:
Click the 3 dots (top right) for the Chrome menu, click More Tools, Extensions. From the extensions page, click the Hamburger, and pick Keyboard Shortcuts. From there, change the AdBlock shortcut to nothing or to whatever.
I had the same issue with a custom expand/collapse shortcut not working in Chrome. I suspected that there might be a conflict with an extension so tried in Incognito Mode (which disables all extensions unless specifically allowed). Still had the problem so thought that wasn’t it until your post reminded me of the extensions keyboard shortcut dialog. Turns out that was the answer after all and Incognito Mode may disable all extensions but it doesn’t loosen their hold on keyboard shortcuts it seems
Sorry to bring this up again 1 year later. I’m facing the same issue, but this time for Firefox. I tried in a Chrome-based browser and the Cmd-. shortcut works as expected, but in Firefox, nothing happens (nothing is logged in the JS console either). I tried disabling all my addons but it didn’t change anything, also tried a different version of Firefox (I usually run on Nightly, so I tried on Beta for a more stable version and still no luck).
Am I the only one in that situation?
Firefox : tried with both Nightly 78 and Beta 77,
on MacOS,
FR mac keyboard (tried with the keyboard settings set to US or German)
