Embeded bullet points, i.e. symbols / components ?!
Hi Dynalist Team / Community,
This is an amazing piece of software, thank you for helping me organize. Instead of only linking to other notes, why don’t we make the ability to embed notes from elsewhere. Like symbols in Figma/Sketch or components in React/Vue, where when you update one, every other instance of that bullet & its children is updated as well. For example:
Note One
  • Point A
  • Point Embedded (this one and it’s children are synced with the below embedded point and it’s children)
    • mirrored point i
    • [deleted here: mirrored point ii]
    • mirrored point iii
  • Point B
Note Two
  • Point A
  • Point B
  • Point Embedded (this one and it’s children are synced with the above embedded point and it’s children)
    • mirrored point i
    • [also deleted here: mirrored point ii]
Thank you for your consideration! If I missed this else where in the forum, please delete this thread.
Troy
Being discussed here: Clone (display item in multiple places)
