dyna makes a new bulletpoint for every linebreak/return in a copied text. This usually blows up the copied secentences and is a little annoying.
the easy fix for that is to ignore the returns in the formatting of the copied text. (as a workaround i am copying into the browers adressline which removes the linebreaks and then and the into dyna)
