I am using Dynalist on iPad with iPadOS 13.4.1 now, and there are a few things I cannot make it work.
- I have set some keyboard shortcuts in the desktop version which work fine, but the shortcuts that contain “option” key do not work anymore. I use the Apple Smart Keyboard.
- Whenever I try to edit an item, with the Smart Keyboard connected, the virtual keyboard will always pop up, which would be perfect if this can be prevented.
- It is not possible to drag an item to change its location like the way I can do in the desktop version. The whole page would just scroll together when I move the mouse.
- In the case that the keyboard and mouse are connected, is it possible to make everything work just as like the desktop version?
Also, the interface of Dynalist in the Chrome browser is similar to that in the iPad App. For example, the document panel is collapsed and it seems that it is not possible to keep it open. The interface in the Safari browser is just like the desktop version. I am a little curious about this difference.
