I’d like to have a Dynalist icon up in my Chrome extensions, so it’s quickly accessible along with my other high-use extensions.
This doesn’t mean I need a Dynalist specialized extension … I just can’t figure out how to get a webpage icon up in the extension list instead of bookmarks (which I don’t use and hence hide).
Unfortunately I’ve never been able to figure out how to do it, with other websites. But now that I used Dynalist so much, it demands space up with the other extensions.
Hmm. This is unfortunately harder than I thought. It requires two clicks (click on the extension, move your cursor down, then click again). Is that ok? Also, right-clicking it and clicking the first button will work as well.
I’ve used this with WorkFlowy, Google Calendar and Dynalist. It’s not a bookmark, but a keyboard shortcut that goes to any existing DL tab or creates a new one if none exist.
It’s quite barebones and the code is sloppy (but not harmful) and the browser will annoy you about it everytime it starts, asking to disable it (quite appealing, isn’t it?), but it’s finally here:
One note about the 4 Smart Shortcuts Chrome extension above.
I use DL in a single tab, and set a single shortcut to “https://dynalist.io”.
But if you have multiple documents open, in multiple tabs, you can set keyboard shortcuts for 4 documents, and each will go to that document or create a new tab if it isn’t already open.
I have updated the extension. It shouldn’t have any of the flaws that I’ve mentioned before, other than simply having to set it up at chrome://extensions, where you need to unzip it, enable developer mode, then load it after locating the folder.
The main benefit of using this is that it doesn’t have any invasive permissions, and the code is free for you to inspect. Let me know if I should make any other changes to it!
