I cannot use any other browsers except Internet Explorer on my work.
So I open dynalist.io and input my credentials.
I expect to see my list of notes
After login to dynalist.io I haven’t seen anything on the screen.
In the developer console I’ve found 15 errors with code CSS3114 for all fonts:
“@font-face failed OpenType embedding permission check. Permission must be Installable.”
The font-face does not have permissions to install with the current webpage.
Obtain the correct permission or licenses for embedding the font.
Windows 10, Internet explorer 11.2515.14393.0
Internet Explorer is obsolete. It doesn’t have the features every modern interactive webpage expects. Are you certain they won’t allow Microsoft Edge which should have been included in Windows 10?
Hi, Philipp!
Great solution but I would not raise that issue if I could do it
I cannot install any app according to information security policy. Installation is forbidden.
