Dim/Grey Hyperlinked entries
Problem
When user creates a hyperlink [[sth]] it will show in search/move-to dialog. That may be desirable but it’s badly distinguishable when it’s deeper (path).
I commonly use structure (for move-to) that goes like as House: Solar, but over the time there’s usually need to reference it elsewhere (even if for improvement of existing own system/structure). That creates two+ items and based on activity (I reckon) the order may differ. That’s okay intuitively, but having little destinction between the original
If it’s not performance hindering, could you…
Solutions
One solution is enough
Make the text more gray, if it contains hyperlink [[ (at least during search/move-to)
(different way/CSS to differentiate hyperlinks during search/move-to)
