I’ve only found a single way to delete an entire document, which is right-click and select delete. I know the keyboard shortcut to delete a list from inside of a document, but it seems like quite the oversight to have to click 3 times to delete any document. (right-click, click delete, click yes).
You’re not missing anything! There’s no current keyboard shortcut for it because it’s not that commonly used. Not as common as deleting an item, at least.
I am curious what you are using documents for where the right click adds up to more time than setting up a hotkey. I delete a document once a month maybe so I’m curious.
I just started using dynalist yesterday, and was testing things and made a bunch of documents (trying to convert my evernote bullet points to OPML for import). I just wanted to delete like 10 things, it was kind of a pain.
