type a space after a word, then a dash/minus symbol -
abc - def
abc- def
it looks like there is no space between the word and the dash even though there is one
it happens on the web version, mobile web on android and windows desktop
the second item in the list has one space on either side, the others are just for comparison
a - a
a - a
a- a
spaces replaced with bullet points:
a••-•a
a•-•a
a-•a
when the first item is copied and pasted elsewhere in dynalist or to another program, the two spaces are removed and it ends up with just one space on either side:
a••-•a becomes a•-•a
