Click on the bullet point to minimise the parent node.
The cursor should move to the parent node, at start or end of line, or perhaps select the whole node.
As a reference point, Workflowy goes to start of line. On the other hand, selecting the whole node would allow any Markdown to stay rendered, so it might be less jarring.
The cursor disappears. Virtually all keyboard shortcuts stop working because nothing is selected. Must click to get things working again.
Windows 10, Chrome 59.
n/a
I think itās an important principle to make sure the focus always goes somewhere, and never disappears. Dynalist normally feels like a snappy text editor, but when this happens it really breaks flow.
If you (Dynalist) want to look it up, I reported this problem to Support last October in an email conversation, although I think Iāve covered the important details here. This problem is an important factor for me if Iām going to subscribe to Pro.
This bug can only be triggered with the mouse right now (because itās the only way to collapse a parent node), but if these keyboard shortcuts are added, they may have the same problem:
I just found a related issue though. At the second reproduce step, if I select the entire child node (Shift-Up, or pressing the hamburger menu button to the left), the selection disappears when I collapse the parent node.
@sys2061 seems fixed on my end, sorry for digging this up ! Weāre cleaning up the bugs and would like to know if the bug is still happening to you? If not weāll close this bug
@Erica@Shida the ārelated issueā is still there - if I select the child node with Shift-Up then click the button to collapse the parent node, the cursor disappears.
Thanks for the update, sorry for the late reply due to the holidays!
I was able toe reproduce the multiselect case of this bug. The issue has been tracked and we will fix it as soon as we can! Thanks again for letting us know.
