just change ur hotkey, theyre all customizable in dynalist
This is only a Pro option.
I have the same problem with the Linux app, where shift+ctrl+i is a common shortcut in other programs.
Given that āCapture into my inboxā is a pro option anyway, it seems like an obvious fix would be to disable this shortcut by default in the non-Pro version.
Edit:
I take this back. While it is documented that modifying shortcuts is a Pro feature, it appears that it isnāt actually and I was just looking in the wrong place.
Edit 2:
Actually Iām on the introductory free trial of Pro, so maybe my initial concern still holds. I guess weāll see what happens when that ends.
Free accounts canāt change default hotkeys. Appearently Slack is the same way. So if the app canāt change them either, the OS will give it to whichever app requested it first.
