Click the settings gear icon.
Select the “keymap” tab.
Try to input “Ctrl+Shift+0” (using the 0 in the number row, not the number pad, for which “Shift+0” is converted to “Ins”, and the shortcut behaves as expected).
The shortcut set to either “Ctrl+Shift+0” or “Ctrl+)”.
It doesn’t register the input, continues waiting for me to input a key combination. “Ctrl+Shift+9”, “Ctrl+Shift+8”, etc. all work correctly, only “Ctrl+Shift+0” fails.
Windows 7
Chrome Version 72.0.3626.121 (Web app).
Again, this is the 0 (Zero) key on the number row, not the 0 key on the number pad. The rest of the number row works correctly, but not the 0.
