Today I found my App in Windows could not sync.
I checked the log, show as follow:
[Updater] Checking for updates…
[Updater] https://dynalist.io/standalone/check?platform=win
[Updater] Failed to apply updates. { Error: write EPROTO 28712:error:14094419:SSL routines:ssl3_read_bytes:tlsv1 alert access denied:c:\projects\electron\vendor\node\deps\openssl\openssl\ssl\record\rec_layer_s3.c:1407:SSL alert number 49
at WriteWrap.afterWrite [as oncomplete] (net.js:833:14) errno: ‘EPROTO’, code: ‘EPROTO’, syscall: ‘write’ }
[Updater] Done checking for updates.
Then I change my network, it became normal.
So I realize the network of my company is denied the app.
Could Dynalist add Proxy function? Thanks.
