Is there a shortcut or command to convert item to note and vice versa?
Ctrl A Ctrl X Ctrl Enter Ctrl V
I think you mean:
- Ctrl A
- Ctrl X
- SHIFT Enter
- Ctrl V
Found an incredibly useful command recently which I thought I’d share here:
- Create an item that contains an item and the content you want as a note. For example, “My journal entry Today I went shopping”
- Select a portion of the item that you want to turn into a note e.g. “I went shopping”
- Hit SHIFT+ENTER
Et voila! As long as the item doesn’t already have a note, the highlighted text will be moved from the item into the notes section
I found this really useful when I decided to move all my item hashtags/labels into the notes field.
