dynalist has become unbareably slow on my phone the last while so regrettably ive decided to move back to workflowy as i cant see the android app getting any improvements any time soon
i have a lot of documents so i figured it would be quicker to make python script that would converts dynalist’s opml so it can be imported into workflowy
you just need to export a document as opml to the downloads folder, run the python script which will open a file picker, then the converted file will show up in the same folder. workflowy doesnt have any GUI to import the .opml file but the contents of the file can be pasted into workflowy from the clipboard
not sure if it converts everything but all my notes were imported correctly anyway, ymmv
