With the cursor on an item, pressing Ctrl+Shift+ 1-6 to add color label to the line item.
Line item to have color label.
Nothing happened. (also I have checked this is not a shortcut used by any other program).
Which browser are you using?
If youâre using a desktop or mobile app, whatâs the version number of Dynalist?
I am using the Windows app. (Not web or Chrome version)
Dynalist 1.3.6.
