Using the color label shortcut āCtrl+Shift+Lā does not work using opera.
Will take a look. Which OS are you on if I may ask?
Win7+Opera
Iām unable to reproduce your issue on Win10+Opera. Have you tested this in other browsers, or on a different computer? Do you see any errors in the javascript console? Ctrl-Shift-i to open developer tools and go to āConsoleā tab.
Thank you for checking the issue. I found the problem. It was the Bitwarden-Plugin, that also uses the Shortcut Str+Sh+L. Changing the shortcut solved the problem ![]()
Got it, thanks!
I had a similar problem and I have written a small guide about this in a different thread, maybe it will be useful to someone:
