- Make a note in a line
- Paste a long code snippet/ any dummy long line in a Note . (Use Shift+enter to enter a Note, then inside double ticks `` paste code.)
- Go to next line, so that rendered code is visible in red.
- Youâll observe line overflow.
properly aligned code
code overflowing out of the UI.
Which operating system are you using? Windows
If youâre using a desktop or mobile app, whatâs the version number of Dynalist? 1.3.0
Are you using any third-party scripts for Dynalist, e.g. PowerPack? Using an autohotkey script(scriptfile on desktop) for Triggering capturing to inbox. Not used in this problem.
2nd, 3rd code snippets have overflow out of the textbox.
in the 2nd screenshot, the overflow is only the last one, as length of line is long. the overflow in 2nd last code snippet disappears as the Keyboard shortcut was closed.
