[Chromium Edge] Cmd + Shift + L not working
  1. Select a block
  2. Hit Cmd + Shift + L to change formatting
  3. It’s not working
The current block should changes the format
Nothing happen
-> MacOS Catalina 10.15.7
Which browser are you using?
-> Microsoft Edge (Chromium-based)
-> No
There’s no error printed out in the Console Log. No HTTP request failed in the Network tab.
I think it conflicts with something in the Edge browser, but I tried to find, doesn’t seems like there’s any specific browser’s feature binded to Cmd + Shift + L.
Does it work on another browser? That’s pretty weird… Also, what keyboard layout do you use?
Sorry, I just checked again. Look like there’s a 3rd party extension that caused an issue (it was 1Password).
Disabled it and the functionality now works as expected. So I think we can close this issue now.
Thank you so much for the great product!
But honestly, I think it would be nice if Dynalist still works even with 1Password extension installed.
