Change or hide part of tags with CSS
Is there anyway to use wildcards in CSS to only manipulate parts of a tag?
I format my Tags extensively to make the autocomplete more helpful, but the readability suffers as a result.
For instance:
##|Reply
##|Draft
##|Build
@@(City)Hamburg
@@(City)Oslo
Used in a task: “##|Build house in @@(City)Hamburg”
Should ideally become:
Reply
Draft
Build
Hamburg
Oslo
Used in a task: “Build house in Hamburg”
I know how to do it on a per tag basis, but that is a bit too manual for my taste. I want to target “##|” and “@@(City)” This way I can add tags without doing any more CSS customisation.
You can target all tags beginning with a string easily:
a[title^=“Filter @@(”]
Should match all your location tags.
As for removing parts of the text, you can‘t do that with CSS directly. But you might be able to use something like text-indent:-30px with overflow:hidden to obscure the beginning of the tag text. I haven‘t tried that, though. I‘d be happy to experiment a bit further if you like.
Thanks for the suggestion. That could work I think. But when I wrote
a[title=“Filter @@(”] {
text-indent:-30px
overflow:hidden
Nothing seems to change.
It was just a guess, I wasn’t sure if that alone would work. Two (perhaps three) things:
There CSS selector must contain ^= to work.
The quote marks around the Filter are not the right kind, but that might have happened when you copied the code into the forum
display:inline-block was missing.
This here works for me, somewhat:
a[title^="Filter @@("] {
    text-indent: -35px;
    overflow: hidden;
    display: inline-block;
This hides the front part of the tag. You’ll have to adapt the -35px depending on your font and screen size.
Screenshot (middle line is in editing mode):
Screenshot 2020-06-16 at 16.49.51
I don’t have any idea how to hide the closing bracket at the end, though.
Oh thank you! This seems to be almost exactly what I was looking for.
Seems there are two different css classes for tags in the node and tags in the notes field. Making this CSS behave a little wonky.
Any tips on how to circumvent this?
Do you have an example?
