Which operating system are you using? Windows 10, macOS 10.15.4
If I try to create a new document with the + button, there are no issues typing a capital S in the name. Itās just inside the document itself.
I have tried on three different keyboards including mobile same result. Iām typing this meSSage so the S works everywhere else.
Weird
/assets/css/theme_autodetect.css?v=20200529214423:1 Failed to load resource: the server responded with a status of 404 ()
185Refused to load the font āā because it violates the following Content Security Policy directive: ādefault-src *ā. Note that āfont-srcā was not explicitly set, so ādefault-srcā is used as a fallback.
main.min.js?v=20200529214423:1 Web environment initialized.
main.min.js?v=20200529214423:1 Persistence user id: W7TA9DRQMochytAyOTtH9Yqz
main.min.js?v=20200529214423:1 Namespace mkE0y9AQfV2X87vzSkgxXPL- hash check: Success
main.min.js?v=20200529214423:1 Push service: connected
DevTools failed to load SourceMap: Could not load content for chrome-extension://hdokiejnpimakedhajhdlcegeplioahd/sourcemaps/onloadwff.js.map: HTTP error: status code 404, net::ERR_UNKNOWN_URL_SCHEME
DevTools failed to load SourceMap: Could not load content for https://dynalist.io/assets/js/ext/ext.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for https://dynalist.io/assets/js/main.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for https://dynalist.io/assets/libs/raven.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for https://dynalist.io/assets/css/theme_default.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for https://dynalist.io/assets/css/print.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for https://dynalist.io/assets/js/ext/jquery.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for https://dynalist.io/assets/css/app.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
