Dear friends,
I have a document where I refresh data at various times. Basically I want to delete all the contents of a file and then add data into it.
To accomplish this, I have to get a list of all nodes in the document and then though the API issue a delete command for each node.
I tried deleting the ‘root’ node, hoping it would delete all children, but that didn’t work.
Is there another approach to a bulk delete (so one command, as opposed to many delete action steps in the API)
Yes I do it in a single call after retrieving the doc. But I am assuming that each action (Delete or insert) goes against the api request limits, even though its done in one call.
If I understand this burst capacity basically means a max of 500 changes in a minute time frame?
This is very much enough.
I have one scenario where I might have to write code to handle for large change operations. I want to sync some small databases as references (probably not more than 400 to 600 inserts max, but if I have to remove what was written, then I will exceed 500).
