[Bug] Tags are still Showing for Archived Documents
Archive a document and navigate to the Tags pane
Tags for archived documents aren’t showing
Tags for archived documents are showing
MacOS Mojave (10.14.6)
Dynalist macOS desktop app v1.3.0
I believe this is due to the fact that files that you just archived doesn’t get unloaded right away (which removes them from the tag pane). There’s a timer that verifies it’s synced and sometimes later unloads it.
Global search on the other hand deliberately skips any documents that is archived, so even if it’s still not yet unloaded, it will skip searching that document.
I’ll file a ticket to have archived documents removed from global tags immediately, but it isn’t too big of an issue right now.
