Bold inserts ** on only right side
  1. Start typing a bullet or note
  2. Press CTRL + B to bold
  3. Type text to be bolded
  4. Press CTRL + B to end bolding
Expected output would be * * WORD TO BE BOLDED * *
Actual output: WORD TO BE BOLDED * * * *
  • Windows 10
  • Chrome
  • Also affects Windows App
Bug introduced very recent; worked last week
Thanks for this bit of information, helps a lot!
As we said in our latest weekly update (Weekly update: 2017 week #2 | The Dynalist Blog), we extensively refactored selection related code, which is the likely cause of this.
Will fix asap, thanks again @ruud!
