I think I researched this issue a while back, falling back to another font isnât automatic or even straightforward.
The best option is probably to try to get a version of the Whitney that can properly display Unicode characters. If thatâs impossible, falling back to a more versatile font is a good idea. If thatâs not possible either, maybe we should just change the default font to something else.
I donât know much about how fonts work, but would it be wrong to have the Whitney font âsubsidizedâ with characters from another font? Not that it wouldnât require more effort than reasonable on your guysâ part or anything.
Personally, I just use Helvetica, and, you know, my worldâs not ending
However, Iâm wondering if given Whitneyâs status as the default font for Dynalist.io, itâs worth merging it with like Helvetica so new users donât get surprised by the poor character support.
