Enter “~~strikethrough~~, $$E=mc^2$$, and ==Highlight==”
[Forum doesn’t render the backslash characters before each of these three items.]
Text without markdown formatting
A backslash followed by markdown formatted text.
Which browser are you using?
Seen on Win 10 and MacOs Mojave
Chrome
Using chromoji on Windows, not MacOs
