- Enable “Auto-focus on first item” in preferences
- Open a saved search via CMD+O
The first result of the saved search should be selected and ready to be modified.
Nothing is selected - there is no way to get to the items with keyboard-only.
Which operating system are you using? MacOS 10.15.1 (19B88)
Which browser are you using? Brave, but I’ve tested in the desktop app
If you’re using a desktop or mobile app, what’s the version number of Dynalist? 1.2.3
Are you using any third-party scripts for Dynalist, e.g. PowerPack? no
N/A
As a developer I love to use my system keyboard only. As I use saved searches in Dynalist countless times every day this issue forces me to always pick-up my mouse thereby interrupting flow.
