Here’s a sample node I get back from an API request:
"id": "uCoBG7ONsEDzIkJH57Uk1234",
"content": "insert content here",
"note": "",
"created": 1543381791234,
"modified": 1543381931234,
"children": []
I figure I can process nodes into trees using their children, but without an ‘index’ value (that is, the order of the items), I’ll end up with a jumbled list with no order. I know this data exists because you can modify it using the ‘move’ command.
Without the ability to order the items in the same way they appear in Dynalist, my use case is impossible.
