I came across Standard Notes a few days ago and I have the say I’m quite impressed. The app is very minimal and clean. The free version is very basic, but by upgrading, you get access to a bunch or extensions or add-ons. These extensions drastically improve the functionality of the app and allow you to do much more. The app is also open-source and 100% private. Your notes are encrypted, you can set up two-factor authentication, password-protected notes, etc. On the other side, it doesn’t support dates or zooming. The way you create folders is by activating the folders extension and creating a tag where the tag itself is the actual folder. You can, however, nest a tag within a tag within a tag, etc. There isn’t an official web clipper, but an SN user created his own web clipper which is available via github. It seems to work pretty well.
I’d love to hear your opinions since I’m seriously considering switching over. You can try the demo version without creating an account. The demo already has all of the themes, extensions or add-ons available to you so you can play around and get the full experience.
