I’m new to Dynalist, so this may be a normal situation.
We’re 2/3 of the way through September, and the Dynalist app in the Android Play Store says “Last updated Jul 8, 2021”, which as far as I can tell is the June update (as listed on The Dynalist Blog). That means that what I have is 2 versions and almost 11 weeks out of date. (I noticed it because I’m experiencing one of the problems fixed with the July update.)
Is this normal? Will the July update be pushed out soon?
