Waiting for the loader to finish loading and showing the list
I can continue using the app.
The app crashes. Even after selecting another list from the menu or selecting a random bullet. Every single time, when opening the app, after about 5-10 seconds the app crashes.
Google Pixel 2 phone
Android 10 / build QP1A / security patch 6 october 2019
Dynalist app version 1.3.7 (last update 7 nov)
No scripts.
I did a Workflowy import recentlyā¦maybe it has to do something with that?
I am using the Google SSO (previously I also had an issue with this where I couldnāt log in, but this seems to be fixed now)
Crashing as in - the app quits with a popup saying it has crashed, correct?
My device is on Android 9 and Iām unable to reproduce this. May I suggest deleting app data/cache and re-login into the app, assuming you donāt have anything saved inside the app that isnāt synced to the website. Let me know if youāre seeing any results from that.
Without result, I did the steps mentioned; cleared the data and cache, even removed the app and rebooted my phone.
Yes. The pop-up shows when I take an action inside the app. When I do nothing and the app just closes. When opening the app again, the Dynalist logo shows, the loader icon andā¦back into the same crashing cycle.
The same thing happens to me. Iāve uninstalled and cleared cache multiple times with no change. Iām on Android 8. In fact its been like this for over a year and itās still happening. This is one main reason Iāve stopped using Dynalist for a while now⦠Want to come back to it but bug still there :((
Iām on Android 11. Dynalist now crashes within 1-3 minutes of every single startup, Without fail. All you have to do is start it and wait. This makes Dynalist essentially unusable.
