Adding Progress Bars
Hi Everyone! I use dynalist for managing my work projects, and I wanted a little progress bar next to each project name. I’ve come up with the following solution.
Using the excellent https://progress-bar.dev site to generate the images.
You can add
- My Project Name ![](https://progress-bar.dev/66/)
  • My Project Name
And if you want them all to line up on the right hand side of the note, you can add this custom css.
.node-displayed-image[src^="https://progress-bar.dev"] {
	float:right;
Example:
wow neat
Very interesting possibility. Thanks for sharing!
I would love to be able to use this. When I copy paste your link (not the code) in Dynalist, the progress bar shows as a text written ā€œImageā€ on it and I need to hover my mouse over it to display the image. Do you have any ideas how to solve this?
Sorry I’m a real noob when it comes to IT stuff!
That is how it looks on a Free account. Inline images is Pro only.
progress-bar.dev no longer works, but https://progress.rocks works the same way
- My Project Name ![](https://progress.rocks/45.4/)
- Save $500 ![](https://progress.rocks/200/?title=Savings&suffix=$&scale=500)
