On mobile it becomes really messy when I have markdown raw URLs that fully expand when selecting an item. I’d like to have the option to create a hyperlink in an item and then when I select said item - the link stays collapsed/embedded. Maybe a long press would expand it again or something.
Bear does it in an interesting way, where the raw link collapses into a little icon and when you tap on it a popup comes up to edit it. Could be a good solution too.
