Sorry, maybe I’m dumb, but I haven’t found neither a way to do this in the interface nor a corresponding feature request.
Imagine I want to export my Dynalist lists to Obsidian. I have a following doc:
The export options are as follows:
test doc
node 1 [node 2](https://dynalist.io/d/NhzZarnud2k_xfC4cQOociTC#z=HssPCW7PawD2aN-C7V83jGv5)
node 2
<body>
<outline text="test doc">
<outline text="node 1 [node 2](https://dynalist.io/d/NhzZarnud2k_xfC4cQOociTC#z=HssPCW7PawD2aN-C7V83jGv5)"/>
<outline text="node 2"/>
</outline>
</body>
There is an internal Dynalist link, but it’s only for the node that is the target of a link. If I wanted to convert the exported file to individual markdown notes, it would be impossible since the original node id’s aren’t listed. Something like this could be helpful:
<body>
<outline text="test doc" node_id="NhzZarnud2k_xfC4cQOociTC">
<outline text="node 1 [node 2](https://dynalist.io/d/NhzZarnud2k_xfC4cQOociTC#z=HssPCW7PawD2aN-C7V83jGv5)" node_id="NhzZarnud2k_xfC4cQOociTC#fxtDbXdmCVxYBsXtgJKK5TT2"/>
<outline text="node 2" node_id="NhzZarnud2k_xfC4cQOociTC#HssPCW7PawD2aN-C7V83jGv5"/>
</outline>
</body>
That way one could easily write a converter to conveniently export all Dynalist data, keeping the internal links intact.
