It would be very useful to be able to expand files. This would not only make it easier to navigate but also to allow for more convenient item movement. Now if I want to move an item with the mouse I have to open both the target location and the item’s location which is challenging when there’s a lot of items.
This is not the same as “split screen”. The file expansion on the left only serves for easier navigation/item movement and is not a full blown view.
This is the only feature I really miss from Workflowy.
I don’t understand.
Do you have a screenshot of expanding files in workflowy? I googled “expand files in workflowy” and only see this https://blog.workflowy.com/the-return-of-expand-and-collapse-all/ but obviously dynalist works exactly the same in that regard
Do you mean expand or something else? Expand generally means clicking the + symbol to collapse and expand the child nodes.
Do you mean document or file? File is generally a .zip you upload for example, document is generally the list.
Are you using the move hotkey? https://blog.dynalist.io/move-item/
Sorry for being vague. You can see what I mean in the video here: https://youtu.be/8aa9cRAici4?t=147 (at 2:27).
In addition to navigation, it is also possible to drag and drop items from the view on the right to the expanded tree on the left.
And yes, I use the move hotkey extensively but quite often I prefer using the mouse instead.
Oh, that is a nice feature. I see someone requested it before https://trello.com/c/Bwzfc0Bj/103-overview-panel .
Hmm, I am not sure it’s the same feature actually but the description is a bit confusing so I might be wrong.
