Up arrow doesn’t move cursor to top item
  1. Position cursor at beginning of first item
  2. Hit up arrow
Cursor moved to document title.
Nothing.
Chrome/macOS
Is this an intended change? @Erica
I’m pretty sure this is not an intended change. Workflowy doesn’t work this way. Moreover, it makes shortcuts like Ctrl-Shift-. to expand all items useless if can’t use the keyboard to first navigate to the title item.
@Erica, can you confirm?
As a workaround, use:
  1. Cursor at the beginning of first item;
  2. Left key.
Thanks for providing this workaround!
@Yatharth_Agarwal, I can’t believe we didn’t find this bug. Will fix!
+@Shida
Fix is ready, and should be deployed soon.
