Tag Auto-Complete not Active in Document Title Notes
Create a new document, and input a ‘#’ in document title notes.
Tag auto-complete window should pop up.
The window didn’t pop up.
Win 10, desktop app version 1.0.47
Looks like a duplicate of this bug: Auto-completion in the root item's note does not work
We’ve added that one to our to-fix list and hopefully will get to it soon.
