When I move an item, I sometimes want to go to the moved location. There is a popup that shows and allows me to do so easily with a link.
However, can I also do so with a keyboard shortcut?
All of the keyboard shortcuts available are what is implemented at the moment. So unfortunately we don’t have a shortcut to jump to moved location
Can it be added to some kind of feature-request list then?
Yes!
Feel free to suggest this feature in http://talk.dynalist.io/c/features.
As you can see from @pottster’s Trello link, we have a lot of features in the works. So it might take a while for feature requests to be implemented.
If you really don’t want to move away from the keyboard, you could use the “Open item finder” shortcut: Ctrl+Shift+O
which allows you to search and jump to a node just the way you would move a node. It is a Pro feature, though, and you would have to search for the destination node twice.
